[Gdal-dev] sterea projection
Thu Nov 10 16:00:40 EST 2005
On 11/10/05, Jan Hartmann <j.l.h.hartmann at uva.nl> wrote:
> Frank Warmerdam wrote:
> > Yes, it should.  Could you perhaps try processing these
> > through "testepsg"?  If you give it a PROJ.4 coordinate
> > system as input it should report various representations,
> > including what it looks like after going to WKT and then
> > back to PROJ.4.
> You are right for "testepsg":
> - testepsg "+proj=sterea ..."
> and
> - testepsg "+proj=sterea +towgs84=..."
> gives the correct output for the generated proj-strings. The towgs
> parameter is present in the second case. "testepsg -t" with a test
> coordinate gives correct different results in both cases.
> However,
> - gdalwarp -s_srs "+proj=sterea..." -t_srs "+proj=longlat..."
> and
> - gdalwarp -s_srs "+proj=sterea +towgs84=..." -t_srs "+proj=longlat..."
> results in two identical output files, both without the towgs84 transform.
Jan,
OK, that is weird.  Could you submit a bugzilla entry with
exact commands, and an input file that demonstrates the problem?
Best regards,
