[Gdal-dev] RE: Reading JPEG2000 JPC and J2K
Norman Barker nbarker at rsinc.com
Fri Nov 11 10:14:55 EST 2005
-----Original Message-----
[mailto:gdal-dev-bounces at lists.maptools.org]On Behalf Of Peng Gao
Sent: Friday, November 11, 2005 2:48 PM
To: gdal-dev at lists.maptools.org
Subject: [Gdal-dev] RE: Reading JPEG2000 JPC and J2K
> From: Peng Gao
> Sent: Friday, November 11, 2005 6:30 AM
> Subject: Reading JPEG2000 JPC and J2K
> I got some images with .jpc and .j2k extensions. Is there any
> way I can read them using GDAL?
> I renamed them to .jp2, and it didn't work. I am using Kakadu codec.
> Gao, Peng
I read the doc on JP2KAK driver again, and it should support JPC. The
problem could be the image I have. Attached is a problem jpc image.
Gao, Peng
I have just tried this with gdalinfo and got
Driver: JP2KAK/JPEG-2000 (based on Kakadu)
Size is 70, 46
Coordinate System is `'
Corner Coordinates:
Upper Left  (    0.0,    0.0)
Lower Left  (    0.0,   46.0)
Upper Right (   70.0,    0.0)
Lower Right (   70.0,   46.0)
Center      (   35.0,   23.0)
Band 1 Block=70x46 Type=Byte, ColorInterp=Red
Band 2 Block=70x46 Type=Byte, ColorInterp=Green
Band 3 Block=70x46 Type=Byte, ColorInterp=Blue
try
gdalinfo --formats
and see if you have got a JPEG2000 driver.
The image is a rose.
Norman
