[Gdal-dev] Gdal compilation problems in Solaris 8
Juan Mari Celihueta jmcm at euskalnet.net
Mon Nov 14 05:22:50 EST 2005
I continue with the same problem. I added the prefix you indicated, and
I also tried as root, but I get exactly the same error message.
I hope someone can help me.
Juan M.
Bruce Bill escribió:
>Seems you don't have system administrator's privilige.
>If you are not root, then you have to put the
>installation under your own account, try add
>  --prefix=/home1/MAPSERVER
>to your configure command line options.
>  hope this helps.
>--- Juan Mari Celihueta <jmcm at euskalnet.net> wrote:
>>Hi all:
>>I'm triyng to compile gdal 1.3.1 in Solaris 8 but I
>>get an error in the
>>make process. I use GNU Make 3.80 and that is the
>>process I follow:
>>$ LD_LIBRARY_PATH=/usr/local/lib
>>$ export LD_LIBRARY_PATH
>>$ ./configure --with-png=internal
>>--with-jpeg=internal
>>--with-geotiff=internal --with-libtiff=internal
>>That's ok, then I execute the make process:
>>$ make
>>and after several minutes of compilation process I
>>get the next error
>>message:
>>ld: fatal: relocations remain against allocatable
>>but non-writable sections
>>collect2: ld returned 1 exit status
>>make[1]: *** [libgdal.la] Error 1
>>make[1]: Leaving directory
>>`/home1/MAPSERVER/gdal-1.3.1'
>>make: *** [check-lib] Error 2
>>I would be very glad if someone could help me.
>>Thanks.
>>Juan M.
>>_______________________________________________
>>Gdal-dev mailing list
>>Gdal-dev at lists.maptools.org
>>http://lists.maptools.org/mailman/listinfo/gdal-dev
>Yahoo! Mail - PC Magazine Editors' Choice 2005
>http://mail.yahoo.com
