[Gdal-dev] vector ilwis driver
Wim Koolhoven koolhoven at itc.nl
Mon Nov 14 09:54:30 EST 2005
Vladimir,
Best way to go at the moment is probably to use the ILWIS export to shapefile. GDAL does support shapefiles.
When need is large enough we may implement a GDAL driver for ILWIS point, segment and/or polygon maps. At the moment such plans do not exist.
For more information about ILWIS look at our website: www.itc.nl/ilwis
regards,
Wim Koolhoven
-----Original Message-----
From: gdal-dev-bounces at lists.maptools.org [mailto:gdal-dev-bounces at lists.maptools.org] On Behalf Of Vladimir Guzmán
Sent: zaterdag 5 november 2005 15:28
To: gdal-dev at lists.maptools.org
Subject: [Gdal-dev] vector ilwis driver
Hello, list.
I'm sorry to disturb you, and I apologize if this is an off-topic question, but it is really important for me to know if I can read Ilwis vector files through gdal.
Or if somebody knows something about this format, or where I can get information about it.
I appreciate any help.
Thanks a lot in advance,
Vladimir Ilich Guzmán R.
http://maintask.com
Gdal-dev mailing list
Gdal-dev at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/gdal-dev
