[Gdal-dev] Arc Binary Coverages
Mon Nov 14 16:50:17 EST 2005
On 11/14/05, Craig Miller <craig.miller at spatialminds.com> wrote:
> Is there a reason why the Arc Binary Coverage driver uses the Coverage
> directory instead of the Workspace that is traditionally used in Arc/Info?
Craig,
I think part of the problem is that neither Daniel or I were Arc/Info users
so we weren't familiar with normal techniques.   Of course, it isn't
a forgone conclusion that we would have treated a workspace as
a datasource even then, but we might have.
Best regards,
> E.g. I would have expected to pass a directory to the workspace like
> /data/county and receive back a list of coverages in that workspace such as:
> Lakes – Type:Polygon
> Lakes – Type:Point (Polygon Labels)
> Lakes – Type:Linestring (Polygon boundary with line topology built)
> Roads – Type:Linestring
> Etc.
> Instead it asks for a path to the coverage /data/county/lakes and returns
> layers named things such as ARC.
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
