[gdal-dev] ecw jpeg 2000 source sdk v3.3 (rc)
Tue Nov 15 09:25:14 EST 2005
On 11/15/05, Rob Cairns <iotc at 3i.co.za> wrote:
> OK I think the problems solved. I added some extra settings in the
> makefile.vc in the frmts/ecw directory and somehow that seemed to do the
> trick. Don't know which one worked or why (or whether it's just the time of
> the month). The result is a very smooth build of gdal-1.3.1 with ER
> Mapper's libecwj2-3.3 on Windows XP with no problems so far.
> The flags are:
> EXTRAFLAGS =    -I$(ECWDIR)\Source\include -DFRMT_ecw -DNO_X86_MMI /DWIN32 /D
> "NDEBUG" /D "_WINDOWS" /D "UNICODE" /D "_UNICODE" /D "_USRDLL" /D
> "NCS_BUILD_WITH_COM" /D "_ATL_STATIC_REGISTRY" /D "_ATL_MIN_CRT" /D
> "_WINDLL" /FD /GS
Rob,
This makes sense.  I am still working with an old hacked version
of the ECW library on win32 that I built with vc6.  Perhaps I should
update to a standard configuration too, and update the makefiles
in CVS accordingly.
Best regards,
