[Gdal-dev] shifted objects in shapefiles
Ed McNierney ed at topozone.com
Tue Nov 15 12:06:14 EST 2005
Bart -
Sean and I are both distinguishing between editing of the shapefiles (as
MapObjects would do) and editing of the .dbf files (which you could do
in Excel, or any low-end database program).  A shapefile editor is less
likely to do strange things.
If you have the same number of records, then there must be another
problem at the other end.  If I read your description right, the
attributes in the first record of the .dbf file should go with the
second record in the .shx/.shp file.  If that's the case, and the number
of records is the same, then the last record in the .dbf file shouldn't
have any .shx record to match it.  What's in the last record?
     - Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA  01863
Phone: +1 (978) 251-4242
Fax: +1 (978) 251-1396
ed at topozone.com
-----Original Message-----
[mailto:gdal-dev-bounces at lists.maptools.org] On Behalf Of Bart van den
Eijnden
Sent: Tuesday, November 15, 2005 11:44 AM
To: sgillies at frii.com
Cc: gdal-dev at lists.maptools.org
Subject: Re: [Gdal-dev] shifted objects in shapefiles
I checked with shpdump and dbfdump, both files have 1629 records.
The files have been edited using MapObjects, so there is continuous
editing going on in these files.
Best regards,
Bart
Bart van den Eijnden
Syncera IT Solutions
Postbus 270
2600 AG  DELFT
tel.nr.: 015-7512436
email: BEN at Syncera-ITSolutions.nl
>>> Sean Gillies <sgillies at frii.com> 15-11-2005 17:36 >>>
Bart,
Any chance that the shapefile's dbf has been edited by hand? Is it
missing a header row? Anomalous row added by accident?
Sean
On Nov 15, 2005, at 9:08 AM, Bart van den Eijnden wrote:
> Hi Ed,
> sorry for the confusion, with "shifted" I meant that the shape object
> of dbf record X seems to be at position X+1, as an example.
> Best regards,
> Bart
> Postbus 270
> 2600 AG  DELFT
Sean Gillies
sgillies at frii dot com
http://zcologia.com/news
Gdal-dev mailing list
Gdal-dev at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/gdal-dev
