[Gdal-dev] Oracle-bindings
Ethan Alpert ealpert at digitalglobe.com
Wed Nov 16 11:27:35 EST 2005
Do an ldd `which ogrinfo`
You should have the Oracle libraries libclntsh.so.x.x and libwtcx.so
linked in if not then there was a problem building ogr note the 'x' is
the version number. I still use 9.0 but can connect to 10g fine.
Also make sure your tnsnames.ora file is correct.
-e
-----Original Message-----
[mailto:gdal-dev-bounces at lists.maptools.org] On Behalf Of Stephan Holl
Sent: Wednesday, November 16, 2005 5:52 AM
To: gdal-dev at lists.maptools.org
Subject: [Gdal-dev] Oracle-bindings
Dear List,
I am trying to force OGR to read layer-information out of oracle-spatial
on a remote maschine. With reference to the oracle-specific site[1] I
tried the given example and adopted to my needs, but it did not work.
ogrinfo -ro OCI:user/pw at 192.168.1.199
Unable to open datasource `OCI' with the following drivers. [...]
which gave me an error. When I am on the localhost-maschine, where
oracle is installed, everything works nicely and I get the list of
layers.
Since I am no oracle-guru (first installation) I am wondering if I need
to configure oracle to accept conncetions from within the internal
network and from other maschines. Perhaps someone can give me a hint
where to look at.
TIA for any pointers.
Best
	Stephan
