[Gdal-dev] Generating a geotiff from netcdf with gdal_translate
ricardd at mathstat.dal.ca ricardd at mathstat.dal.ca
Wed Nov 16 15:20:24 EST 2005
Hello all,
I built version 1.3.1.0 from source and it fixed my problem.
Thanks for the suggestions.
Dan
> ricardd at mathstat.dal.ca wrote:
>>Hello gdal-dev,
>>I'm very new to gdal so please cope with my ignorance.
>>I have a netcdf file of bathymetry that I use in GMT. I'd like to
>> generate
>>a geotiff version of the same data. There was an earlier posting on this
>>list that suggested that gdal_translate can do this. However, I keep
>>getting a segmentation fault when I invoke the command:
>>>gdal_translate -a_srs 'EPSG:4326' bathymetry.grd outfile.tif
>>Could the gurus point out what's wrong with the above? Am I missing some
>>configuration to get gdal and netcdf to talk to each other?
>>I'm running GDAL 1.2.6.0 and netcdf 3.5.0-7.1 on Ubuntu breezy.
>>Cheers,
>>Dan
>>_______________________________________________
>>Gdal-dev mailing list
>>Gdal-dev at lists.maptools.org
>>http://lists.maptools.org/mailman/listinfo/gdal-dev
> "Well, I screwed it up real good, didn't I?"
> -- Richard M. Nixon
