[Gdal-dev] SOLVED: Oracle-bindings
Stephan Holl sholl at gmx.net
Fri Nov 18 05:29:17 EST 2005
Hello Ethan, all,
On Thu, 17 Nov 2005 14:11:53 -0700 "Ethan Alpert"
<ealpert at digitalglobe.com> wrote:
> I don't know maybe you can check the configure output. If it needed
> more libs you'd think it wouldn't have compiled or ldd would've had a
> (not found) next to a library in the list of libs linked in.
I copied the whole folder of the instant client again and now,
everything is working... strange. The libs were exactly the same.
So when compiling the bindings, the standard-client with the
header-files is needed.
When using the resulting binary-package at another maschine, the
instant-client-libs are sufficient, as long as the whole folder is used
and the appropriate tnsnames.ora is exported in TNS_ADMIN.
Sorry for any confusion.
Best
	Stephan
Desc: not available
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20051118/00a36947/signature.bin
