[Gdal-dev] Re: compiling with Visual Studio 2005 Beta 2 (VC 8)
Bart van den Eijnden bartvde at xs4all.nl
Sat Nov 19 13:05:13 EST 2005
Hi Frank,
this was 1.3.1 indeed. I just tried the last nightly and it builds fine.
Best regards,
Bart
Frank Warmerdam wrote:
>On 11/19/05, Bart van den Eijnden <bartvde at xs4all.nl> wrote:
>>I forgot to mention, the compile seems to fail mainly on mitab:
>>mitab_feature.cpp(6480) : error C2440: '=' : cannot convert from 'const
>>char *' to 'char *'
>>        Conversion loses qualifiers
>>mitab_feature.cpp(6485) : error C2440: '=' : cannot convert from 'const
>>char *' to 'char *'
>Bart,
>This can be easiliy corrected with a cast, but the line number
>doesn't match the current source.  Was this with 1.3.1?  Could
>you try a nightly snapshot and point out the errors?
>Best regards,
>I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
>light and sound - activate the windows | http://pobox.com/~warmerdam
>and watch the world go round - Rush    | Geospatial Programmer for Rent
