[Gdal-dev] WKB
Bart van den Eijnden BEN at Syncera-ITSolutions.NL
Mon Nov 21 04:43:51 EST 2005
Hi list,
I am trying to connect OGR through ODBC to a WKB database. The WKB database was created using TatukGIS (www.tatukgis.com).
I am getting the following error back from OGR:
C:\Programs\FWTools0.9.9>ogrinfo ODBC:synfonie/synfonie at tatukgistest
ERROR 1: No column definitions found for table 'bis_loc_FEA', layer not usable.
INFO: Open of `ODBC:synfonie/synfonie at tatukgistest'
using driver `ODBC' successful.
This is the record in the GEOMETRY_COLUMNS table (in XML format):
<main>
  <DATA_RECORD>
    <F_TABLE_NAME>bis_loc_FEA</F_TABLE_NAME>
    <F_GEOMETRY_COLUMN>GID</F_GEOMETRY_COLUMN>
    <G_TABLE_NAME>bis_loc</G_TABLE_NAME>
    <STORAGE_TYPE>1</STORAGE_TYPE>
    <GEOMETRY_TYPE>11</GEOMETRY_TYPE>
    <COORD_DIMENSION>2</COORD_DIMENSION>
    <MAX_PPR>0</MAX_PPR>
    <SRID>1</SRID>
  </DATA_RECORD>
</main>
The tables are defined as:
CREATE TABLE BIS_LOC
  GID           NUMBER(9)                       NOT NULL,
  XMIN          FLOAT(126),
  YMIN          FLOAT(126),
  XMAX          FLOAT(126),
  YMAX          FLOAT(126),
  WKB_GEOMETRY  BLOB
CREATE TABLE BIS_LOC_FEA
  LOC_CODE   VARCHAR2(11 BYTE),
  XCOORD     NUMBER(9),
  YCOORD     NUMBER(9),
  TAB_LABEL  VARCHAR2(5 BYTE)
What could be the problem? Thanks in advance. It seems TatukGIS does not write SRS info, but that does not seem to be the cause of the above error.
Best regards,
Bart
Syncera IT Solutions
Postbus 270
2600 AG  DELFT
tel.nr.: 015-7512436
email: BEN at Syncera-ITSolutions.nl
