[Gdal-dev] WKB
Bart van den Eijnden BEN at Syncera-ITSolutions.NL
Mon Nov 21 05:21:51 EST 2005
Okay, I am one step further, it seemed to be caused by the wrong case in the F_TABLE_NAME and G_TABLE_NAME fields.
But now ogrinfo does not report any geometries, it just reports the attributes from the  F_TABLE_NAME table.Why is this?
C:\Programs\FWTools0.9.9>ogrinfo ODBC:synfonie/synfonie at tatukgistest BIS_LOC_FEA  -summary
INFO: Open of `ODBC:synfonie/synfonie at tatukgistest'
using driver `ODBC' successful.
Layer name: BIS_LOC_FEA
Geometry: Unknown (any)
Feature Count: 3444
Layer SRS WKT:
(unknown)
LOC_CODE: String (11.0)
XCOORD: Real (9.0)
YCOORD: Real (9.0)
TAB_LABEL: String (5.0)
OGRFeature(BIS_LOC_FEA):508
  LOC_CODE (String) = AA060700163
  XCOORD (Real) =     78898
  YCOORD (Real) =    444712
  TAB_LABEL (String) = (null)
OGRFeature(BIS_LOC_FEA):509
  LOC_CODE (String) = AA060700165
  XCOORD (Real) =     78720
  YCOORD (Real) =    444737
Best regards,
Bart
Syncera IT Solutions
Postbus 270
2600 AG  DELFT
tel.nr.: 015-7512436
email: BEN at Syncera-ITSolutions.nl
>>> "Bart van den Eijnden" <BEN at syncera-itsolutions.nl> 11/21/2005 10:43 AM >>>
Hi list,
I am trying to connect OGR through ODBC to a WKB database. The WKB database was created using TatukGIS (www.tatukgis.com).
I am getting the following error back from OGR:
ERROR 1: No column definitions found for table 'bis_loc_FEA', layer not usable.
This is the record in the GEOMETRY_COLUMNS table (in XML format):
<main>
  <DATA_RECORD>
    <F_TABLE_NAME>bis_loc_FEA</F_TABLE_NAME>
    <F_GEOMETRY_COLUMN>GID</F_GEOMETRY_COLUMN>
    <G_TABLE_NAME>bis_loc</G_TABLE_NAME>
    <STORAGE_TYPE>1</STORAGE_TYPE>
    <GEOMETRY_TYPE>11</GEOMETRY_TYPE>
    <COORD_DIMENSION>2</COORD_DIMENSION>
    <MAX_PPR>0</MAX_PPR>
    <SRID>1</SRID>
  </DATA_RECORD>
</main>
The tables are defined as:
CREATE TABLE BIS_LOC
  GID           NUMBER(9)                       NOT NULL,
  XMIN          FLOAT(126),
  YMIN          FLOAT(126),
  XMAX          FLOAT(126),
  YMAX          FLOAT(126),
  WKB_GEOMETRY  BLOB
CREATE TABLE BIS_LOC_FEA
  LOC_CODE   VARCHAR2(11 BYTE),
  XCOORD     NUMBER(9),
  YCOORD     NUMBER(9),
  TAB_LABEL  VARCHAR2(5 BYTE)
What could be the problem? Thanks in advance. It seems TatukGIS does not write SRS info, but that does not seem to be the cause of the above error.
Best regards,
Bart
Postbus 270
2600 AG  DELFT
Gdal-dev mailing list
Gdal-dev at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/gdal-dev
