[Gdal-dev] problem with config...
Wed Nov 23 11:15:35 EST 2005
On 11/23/05, Matthew Roberson <adidassneakers at yahoo.com> wrote:
> Hello,
> I am attempting to compile gdal-1.3.1 on OS X 10.4.2.
> I am getting an error when I run config and I am
> hoping somebody can help me figure out how to resolve
> the problem.
> The error is:
> checking for XTIFFClientOpen in -lgeotiff... no
> configure: error: We require at least GeoTIFF 1.2.1.
> Consider using the one supplied with GDAL
Matthew,
You might want to look in config.log to see if there are clues
to why the test for XTIFFClientOpen failed.  I assume you do
have a recent copy of libgeotiff?
If you have no compelling need to use an external libgeotiff
and libtiff, you can just drop the configure switches for these
and let GDAL use its internal copy.
Best regards,
