[Gdal-dev] assign nodata to existing tif?
Fri Nov 25 14:58:01 EST 2005
On 11/25/05, Matt Wilkie <matt.wilkie at gov.yk.ca> wrote:
> Hello,
> How do I define the nodata value in an existing geotiff?
> I've created some mosaicks with gdal_merge, which doesn't assign nodata,
> and now I want to tell those mosaicks which value is nodata (so that
> when I gdal_translate them with jpeg compression the nodata values are
> excluded from the resampling).
Matt,
You can use the -a_nodata switch to gdal_translate to treat
a particular value as nodata.  However, this doesn't normally
affect the nearest neighbour resampling done by gdal_translate.
Perhaps you mean for the CDED writer, which is pretty special
in this regard?
Best regards,
