[Gdal-dev] gdal_translate error with big file
Aaron Racicot aaronr at z-pulley.com
Tue Nov 29 00:02:44 EST 2005
Not 100% sure, but I believe the max file size for a Tiff/GeoTiff is 4GB due
to 32 bit offsets.  Your error would seem to confirm that.
Aaron
-----Original Message-----
[mailto:gdal-dev-bounces at lists.maptools.org] On Behalf Of Shoaib Burq (VPAC)
Sent: Monday, November 28, 2005 8:30 PM
To: gdal-dev at lists.maptools.org
Subject: [Gdal-dev] gdal_translate error with big file
Hi
Trying a coversion from ArcInfo ascii to GeoTiff with internal tiling.
This is to understand internal tiling better.
The file size is 6.1GB
Currently running FWTools on winXP:
$ gdalinfo --version
GDAL 1.3.1.0, FWTools 1.0.0a6, released 2005/11/03
Upon running the gdal_translate to convert the ascii grids to GeoTiff we
encountered the following error:
$ gdal_translate -co "TFW=YES" -co "TILED=YES" -of GTiff SeafloorElevation
.asc SeafloorElevation_tiled.tif
Input file size is 34799, 29478
0...10...20...30.ERROR 3: Cant seek to offset -1 in input file to read
data.
ERROR 1: IReadBlock failed at X offset 0, Y offset 9789
ERROR 1: GetBlockRef failed at X block offset 0, Y block offset 9789
Works fine using ArcGISs ArcToolBox ASCIItoGRID utility.
Gdalinfo is happy to read the ascii file too:
C:\data>gdalinfo SeafloorElevation.asc
Driver: AAIGrid/Arc/Info ASCII Grid
Size is 34799, 29478
Coordinate System is `'
Origin = (246331.250000,5749620.750000)
Pixel Size = (0.50000000,-0.50000000)
Corner Coordinates:
Upper Left  (  246331.250, 5749620.750)
Lower Left  (  246331.250, 5734881.750)
Upper Right (  263730.750, 5749620.750)
Lower Right (  263730.750, 5734881.750)
Center      (  255031.000, 5742251.250)
Band 1 Block=34799x1 Type=Int16, ColorInterp=Undefined
   NoData Value=-9999
Is this a "big file" support issue? if so how do I get around it?
Thanks for the help
chrs
Shoaib Burq
Gdal-dev mailing list
Gdal-dev at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/gdal-dev
