[Gdal-dev] Re: GDAL 1.3.1 Alpha 2 Released
Howard Butler hobu at iastate.edu
Sun Oct 2 18:46:59 EDT 2005
It is a happy coincidence that the gdalautotest suite has worked well
to allow us to exercise the next generation bindings, but it is my
understanding that they were developed to test GDAL itself, and not
necessarily the script bindings.
The testing suite as it currently stands can require many different
drivers that are not enabled by default on all builds and contain
significantly sized data to test the capabilities of certain drivers.
I wouldn't want to bloat the distribution of GDAL with all of the
test overhead.
My third point is that the next gen bindings development has been
disruptive enough without turning over the apple cart of testing at
this time.  I vote (there's only one vote that counts, btw ;) that we
hold the testing suite still until the dust settles on next gen
development and then maybe take a look at it.
Another thing to add is that an even worse scenario is to have *two*
test suites like MapServer has.  MapServer has the MapScript unit
tests (which have good coverage of methods and calls) and the
MapServer test suite which has coverage of the mechanicals of
MapServer.  It has made it difficult to divine in an automated way
what might be going on, and the fact that there are two different
test harnesses with two different invocations unnecessarily adds to
the developer overhead IMO.
Howard
At 12:11 AM +0300 10/3/05, Ari Jolma wrote:
>Charlie Savage kirjoitti:
>>I just meant having all the tests in one place, i.e., gdalautotest.
>>For Ruby, I just created a Ruby directory and then ported some of
>>the Python tests to Ruby.  But I think you should write the tests
>>that are most appropriate for the language.
>I don't see much point in porting the gdalautotest code to Perl
>since the scope of that is so much larger than the test code for the
>Perl API.
>>I tend to agree with you that I'd like the tests in the GDAL CVS
>>project (makes them more obvious), but I think that a matter of
>>debate (integrated tests or separate tests) without a clearly
>>better answer.
>Let's have that debate? Or was there such already? I can't think of
>any good reason to keep the tests separate but many to have them
>integrated and a standard part of any compilation+installation.
>Cheers,
>Ari
>Prof. Ari Jolma
>Kartografia ja Geoinformatiikka / Cartography and Geoinformatics
>Teknillinen Korkeakoulu / Helsinki University of Technology
>POBox 1200, 02015 TKK, Finland
>Email: ari.jolma at tkk.fi URL: http://www.tkk.fi/~jolma
>_______________________________________________
>Gdal-dev mailing list
>Gdal-dev at lists.maptools.org
>http://lists.maptools.org/mailman/listinfo/gdal-dev
