[Gdal-dev] SWIG and dynamic versus static libraries
Charlie Savage cfis at interserv.com
Sun Oct 2 19:29:10 EDT 2005
Here is another interesting one that came up testing the Ruby SWIG
bindings for OSR.
When testing a State Plane coordinate system, GDAL output a warning that
it could not find "stateplane.csv."  It turns out this happened because
GDAL couldn't find the GDAL directory.
You can fix this by calling CPLSetConfigOption.  This API is exposed in
the gdal module, but not in the osr module.  So the Ruby code:
Gdal::Gdal.set_config_option('GDAL_DATA', dir)
srs = Gdal::Osr::SpatialReference.new
srs.set_state_plane(403, 1) # California III NAD83
But this didn't work. The reason is because I have been compiling the
Ruby extensions against the Windows static library and not the DLL -
thus the GDAL module and the ORS modules each have their own memory area
for the various CPL variables.
What is the best way to handle this:
1.  Require that extensions for all languages must compile against the
DLL on windows and shared libraries on Linux?  From what I can see, this
is what the Python extension is doing (it ignores the DLLBUILD option in
  gdal/nmake.opt)
2.  Expose the CPL APIs (there about ten methods exposed via SWIG right
now) in each module (GDAL, OGR, OSR), thereby allowing either static or
dynamic linking?
Thanks,
Charlie
