[Gdal-dev] SWIG / TestCapability / Ruby
Kevin Ruland kruland at ku.edu
Mon Oct 3 07:43:22 EDT 2005
> Anyway, the good news is that SWIG seems to define the appropriate
> bool typemaps already for each language, so I don't think we need to
> introduce a fake BOOLEAN type.  Instead, I think all we have to do is
> change the return type from int to bool on the appropriate methods.
Cool.
> Thus in ogr.i:
> int TestCapability (const char *cap) {
>     return OGR_Dr_TestCapability(self, cap);
> Becomes:
> bool TestCapability (const char *cap) {
Ok.
> In the wrapper method, SWIG then typecasts the results from
> OGR_Dr_TestCapability to a bool, and applies the languages bool
> typemap (which they seem to all have).  So:
> static PyObject *_wrap_Driver_TestCapability(PyObject *, PyObject *args) {
>     PyObject *resultobj = NULL;
>     result = (bool)OGRDriverShadow_TestCapability(arg1,(char const
> *)arg2);
>    /* language specific typemap here, this is python */
>       resultobj = SWIG_From_bool(static_cast<bool >(result));
It inserts the cast for you?  If so, this is really the way to go.  This
is no longer C-99 code though.  Going to have to ask frank about that.
If he wants C-99 then we'll have to cobble together our own typemap and
insert a #define bool int.
> I suppose we could do this:
>     if (result = OGR_Dr_TestCapability(self, cap))
>        return true;
>    else
>       return false;
Yuck.  if we don't have to do this, we shouldn't.
> But I don't think we have to.
> The methods in ogr.i I changed are:
> Equal
> testcapability
> IsFieldSet
> Intersect
> Equal
> Disjoint
> Touches
> Crosses
> Within
> Contains
> Overlaps
> I'd be glad to check it in or send it to you if you want to take a
> look and test with Python.
> Charlie
