[Gdal-dev] Oracle locator/spatial bindings w/ ogr
Stephan Holl sholl at gmx.net
Tue Oct 4 09:54:52 EDT 2005
Hello Frank,
> Stephan,
> I would suggest a "make clean ; make" to ensure that all the correct
> files were re-compiled when you added in OCI support.  I don't know
> how you have your shared library searching setup but it does seem
> likely that you are picking up an old libgdal.so in /usr/local/lib so
> I would suggest installing and then trying again.
I have found the error... It was the search order for my shared libs. Thanks
for the hint. After reorganizing the libs OCI support was there!
Best
     Stephan
GMX DSL = Maximale Leistung zum minimalen Preis!
2000 MB nur 2,99, Flatrate ab 4,99 Euro/Monat: http://www.gmx.net/de/go/dsl
