[Gdal-dev] linking problems with MrSID library
David Burken dburken at comcast.net
Tue Oct 4 13:14:04 EDT 2005
The below worked for me on Fedora Core 3 i686 gcc gcc version 3.4.2.
Thanks!
Dave
William Kyngesburye wrote:
> On Oct 4, 2005, at 12:56 AM, Bill Binko wrote:
>> Alright, after much banter, and a few curses, Frank and I seem to have
>> found a way to make MrSID work cleanly without having to change  between
>> GCC 3.x compilers.  I have not tested this with 4.x, but it just might
>> work.
>> Only two things need to change:
>> 1) You can't use libtool.  (If a libtool person wants to get with me
>> offline we can workout what's needed.)  When you run configure add
>> --without-libtool.
>> 2) After configure, edit GDALmake.opt and add the full path to the
>> appropriate c++ library for your version of MrSID's SDW (for my
>> version 5,
>> it's /usr/lib/libstdc++.so.5) to the end of your LIBS variable.
>> Build and install, all should be right with the world.
> No go.  No missing symbols, but tons of multiple definitions
> warnings, that eventually cause it to fail.
> ld: warning multiple definitions of symbol ___gxx_personality_v0
> /usr/lib/gcc/darwin/3.3/libstdc++.a(eh_personality.o) private
> external definition of ___gxx_personality_v0 in section (__TEXT,__text)
> /usr/lib/gcc/powerpc-apple-darwin8/4.0.0/libstdc++.dylib(single
> module) definition of ___gxx_personality_v0
> [many, many more]
> ld: multiple definitions of symbol
> __ZStplIcSt11char_traitsIcESaIcEESbIT_T0_T1_ES3_RKS6_
> /usr/lib/gcc/darwin/3.3/libstdc++.a(string-inst.o) private external
> definition of __ZStplIcSt11char_traitsIcESaIcEESbIT_T0_T1_ES3_RKS6_
> /usr/bin/libtool: internal link edit command failed
> Maybe it doesn't like mixing the static and dynamic libraries?
> (there's no choice there - static for the old, dynamic for the new)
> Note: using libtool and adding the GCC 3.3 libstdc++ to LIBS also
> works for me (with the same multi defs problem), it's not stripping
> out what I add to LIBS, and it IS using LIBS.  At least without
> libtool, I could play with linker options to try to get rid of the
> multi defs problem, but the few options I tried didn't help.
> I guess I'll just continue to wait for LizardTech to get crackin on
> an update.  The conversion program they provide in the DSDK still
> works in Mac OS 10.4, so at least I have some sort of conversion
> option from MrSID.
>> Go back to your default build: the one that ended up with only linker
>> errors.  Go ahead and build: you'll fail at link time on the
>> applications.
> It has always failed at the library link step.  Never got to the
> applications.
> William Kyngesburye <kyngchaos at kyngchaos.com>
> http://www.kyngchaos.com/
> "Time is an illusion - lunchtime doubly so."
> - Ford Prefect
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
