[Gdal-dev] error in compiling py-Projection
Wed Oct 5 21:38:50 EDT 2005
On 10/5/05, John C Cartwright <John.C.Cartwright at noaa.gov> wrote:
> Hello All,
> I'm tring to compile py-Projection on linux (RHEL WS3). Can anyone
> provide some guidance on how to modify the setup.py?  It seems that
> proj4 libs/includes are required (which I have), but it also seems to be
> looking for a "pyprojection/proj/src" which I don't.
John,
It sounds like you need to unpack the proj.4 source distribution in
your pyprojection directory, and then rename it to proj.
This question would really be more appropriate on the proj.4 list.
Best regards,
