[Gdal-dev] compile error GDAL 1.3.0
Thu Oct 6 10:19:31 EDT 2005
On 10/5/05, Dylan Beaudette <dylan at iici.no-ip.org> wrote:
> I get the error:
> gcore/gdal_misc.cpp:1308: error: `OGRSpatialReference' undeclared (first use
>    this function)
> gcore/gdal_misc.cpp:1308: error: (Each undeclared identifier is reported only
>    once for each function it appears in.)
> gcore/gdal_misc.cpp:1308: error: syntax error before `,' token
> gcore/gdal_misc.cpp:1311: error: `oSRS' undeclared (first use this function)
> gcore/gdal_misc.cpp:1312: error: `oSRSGeogCS' undeclared (first use this
>    function)
> any ideas ?
Dylan,
That is very stange.  gdal_misc.cpp 1.70 (in GDAL 1.3.0) includes
ogr_spatialref.h which includes the OGRSpatialReference declaration.
I don't see how OGRSpatialReference could be not defined in
gdal_misc.cpp.  You might want to check if there is a truncated
ogr_spatialref.h sitting around in /usr/local/include or the local
build for some reason.
You might also want to work from 1.3.1 if you are setting up a new
system.
Best regards,
