Fix for building perl bindings was Re: [Gdal-dev] Newbie with OGR Perl bindings
Matt Foster Matthew.Foster at noaa.gov
Fri Oct 7 10:49:38 EDT 2005
Kevin,
OK, I started fresh with a 'make clean', and then did these steps...
./configure --with-netcdf=<path to netcdf>
make
make install
This went fine, and everything is installed under /usr/local.  Then
things go bad...
cd swig/perl
make
make fails trying to compile gdal_wrap.cpp with SWIG_NewPointerObj being
undeclared.  I tried adding the -L/usr/local/lib to the Makefile.PL, as
you suggested (even though /usr/local is default), and even added
/usr/local/lib to LD_LIBRARY_PATH, and it fails in the same place with
the same error.
Matt
Kevin Ruland wrote:
>Matt,
>There appears to be some problems with 'make install' in the perl
>bindings - there are some work-arounds for it and if you use --prefix
>things get a little harder.
>If you decide to install gdal in either /usr/local or /usr/ (this is the
>case when you don't use --prefix in ./configure),
>the best option is to not use the --with-perl option, but instead do this:
>./configure --normal-configure-options  (omit the --with-perl option)
>make
>make install
>cd swig/perl
>make
>make install
>This should install the perl module correctly.
>If you desire to install gdal in a non-default location you will need to
>hack the swig/perl/Makefile.PL script to get the build to function
>correctly.
>./configure --prefix=myprefix --normal-configure-options (omit the
>--with-perl option)
>make
>make install
>cd swig/perl
>-- edit the Makefile.PL and change all the lines with LIB => "-lgdal" to
>LIB => '-Lmyprefix/lib -lgdal'
>make
>make install
>We are currently working on a platform independent way to make this more
>automatic.  It should make it into cvs shorly, and in the 1.3.2
>release.  Until then we'll have to struggle a little more.
>Best of luck.
>Kevin
>Matt Foster wrote:
>>Ari Jolma wrote:
>>>Matt Foster kirjoitti:
>>>>Would anyone have a sample code snippet they'd be willing to share,
>>>>showing how to create a simple point shapefile with the OGR Perl
>>>>binding?
>>>look at  the test.pl in swig/perl, it creates and opens raster and
>>>vector data files
>>>Ari
>>Ari,
>>Something is wrong with my installation here.  When I tried to run
>>test.pl it said that it could find a loadable module for gdalconst,
>>despite the fact that gdalconst.pm is in my @INC list.  I think in my
>>effort yesterday to get around the compilation failure of
>>gdal_wrap.cpp, I fouled up the installation.  I think I need to step
>>back, and start fresh.
>>I worked on the assumption yesterday that to get the Perl bindings
>>built and installed that I would do these steps from the gdal base
>>directory (I also use netCDF)...
>>./configure --with-netcdf=<path to netcdf> --with-perl
>>make
>>make install
>>Is that incorrect?  If those are indeed the right steps, then I need
>>to figure out why gdal_wrap.cpp fails to build.
>>Matt
>_______________________________________________
>Gdal-dev mailing list
>Gdal-dev at lists.maptools.org
>http://lists.maptools.org/mailman/listinfo/gdal-dev
"Those who would sacrifice essential liberties for a little
temporary safety deserve neither liberty nor safety."
-- Benjamin Franklin
