Fix for building perl bindings was Re: [Gdal-dev] Newbie with OGRPerl bindings
Ari Jolma ari.jolma at tkk.fi
Fri Oct 7 13:04:05 EDT 2005
Matt Foster kirjoitti:
> Sorry, I guess I didn't include the exact error message...
> gcc -c  -I../../gcore -I../../alg -I../../ogr -I../../port
> -D_REENTRANT -D_GNU_SOURCE -DTHREADS_HAVE_PIDS -DDEBUGGING
> -fno-strict-aliasing -I/usr/local/include -D_LARGEFILE_SOURCE
> -D_FILE_OFFSET_BITS=64 -I/usr/include/gdbm -O2 -g -pipe -march=i386
> -mcpu=i686   -DVERSION=\"\" -DXS_VERSION=\"\" -fPIC
> "-I/usr/lib/perl5/5.8.0/i386-linux-thread-multi/CORE"   gdal_wrap.cpp
> gdal_wrap.cpp: In function `void
> _wrap_Dataset_GetGCPs(PerlInterpreter*, CV*)':
> gdal_wrap.cpp:4877: `SWIG_NewPointerObj' undeclared (first use this
> function)
> gdal_wrap.cpp:4877: (Each undeclared identifier is reported only once
> for each
>   function it appears in.)
which version gdal do you have? in gdal-1.3.1 line 4877 is not in
wrap_Dataset_GetGCPs and SWIG_NewPointerObj is only defined not used
gdal_wrap.cpp in 1.3.1 is 235345 bytes and its header says:
..automatically generated by swig 1.3.26
Ari
> make[1]: *** [gdal_wrap.o] Error 1
> Matt
> Ethan Alpert wrote:
>> What's the error? Was it in a previous post?
>> -e
>> -----Original Message-----
>> From: gdal-dev-bounces at lists.maptools.org
>> [mailto:gdal-dev-bounces at lists.maptools.org] On Behalf Of Matt Foster
>> Sent: Friday, October 07, 2005 8:50 AM
>> To: Kevin Ruland
>> Cc: gdal-dev at lists.maptools.org
>> Subject: Re: Fix for building perl bindings was Re: [Gdal-dev] Newbie
>> Kevin,
>> OK, I started fresh with a 'make clean', and then did these steps...
>> ./configure --with-netcdf=<path to netcdf>
>> make
>> make install
>> This went fine, and everything is installed under /usr/local.  Then
>> things go bad...
>> cd swig/perl
>> make
>> make fails trying to compile gdal_wrap.cpp with SWIG_NewPointerObj being
>> undeclared.  I tried adding the -L/usr/local/lib to the Makefile.PL,
>> as you suggested (even though /usr/local is default), and even added
>> /usr/local/lib to LD_LIBRARY_PATH, and it fails in the same place
>> with the same error.
>> Matt
>> Kevin Ruland wrote:
>>> Matt,
>>> There appears to be some problems with 'make install' in the perl
>>> bindings - there are some work-arounds for it and if you use
>>> --prefix things get a little harder.
>>> If you decide to install gdal in either /usr/local or /usr/ (this is
>>> the case when you don't use --prefix in ./configure), the best
>>> option is to not use the --with-perl option, but instead do this:
>>> ./configure --normal-configure-options  (omit the --with-perl
>>> option) make make install
>>> cd swig/perl
>>> make
>>> make install
>>> This should install the perl module correctly.
>>> If you desire to install gdal in a non-default location you will
>>> need to hack the swig/perl/Makefile.PL script to get the build to
>>> function correctly.
>>> ./configure --prefix=myprefix --normal-configure-options (omit the
>>> --with-perl option) make
>>> make install
>>> cd swig/perl
>>> -- edit the Makefile.PL and change all the lines with LIB => "-lgdal"
>> to
>>> LIB => '-Lmyprefix/lib -lgdal'
>>> make
>>> make install
>>> We are currently working on a platform independent way to make this
>>> more automatic.  It should make it into cvs shorly, and in the 1.3.2
>>> release.  Until then we'll have to struggle a little more.
>>> Best of luck.
>>> Kevin
>>> Matt Foster wrote:
>>>>>> Would anyone have a sample code snippet they'd be willing to
>>>>>> share, showing how to create a simple point shapefile with the
>>>>>> OGR Perl binding?
>>>>> look at  the test.pl in swig/perl, it creates and opens raster and
>>>>> vector data files
>>>>> Ari
>>>> Ari,
>>>> Something is wrong with my installation here.  When I tried to run
>>>> test.pl it said that it could find a loadable module for gdalconst,
>>>> despite the fact that gdalconst.pm is in my @INC list.  I think in
>>>> my effort yesterday to get around the compilation failure of
>>>> gdal_wrap.cpp, I fouled up the installation.  I think I need to
>>>> step back, and start fresh.
>>>> I worked on the assumption yesterday that to get the Perl bindings
>>>> built and installed that I would do these steps from the gdal base
>>>> directory (I also use netCDF)...
>>>> ./configure --with-netcdf=<path to netcdf> --with-perl
>>>> make
>>>> make install
>>>> Is that incorrect?  If those are indeed the right steps, then I
>>>> need to figure out why gdal_wrap.cpp fails to build.
>>>> Matt
>>> Gdal-dev mailing list
>>> Gdal-dev at lists.maptools.org
>>> http://lists.maptools.org/mailman/listinfo/gdal-dev
Prof. Ari Jolma
Kartografia ja Geoinformatiikka / Cartography and Geoinformatics
Teknillinen Korkeakoulu / Helsinki University of Technology
POBox 1200, 02015 TKK, Finland
Email: ari.jolma at tkk.fi URL: http://www.tkk.fi/~jolma
