[Gdal-dev] Possible bug in getGeometryType() version 1.3.0
Chapman, Martin MChapman at sanz.com
Mon Oct 10 17:27:23 EDT 2005
Sean,
Hmmm, ok that is good info.  I will dig into the 1.3.0 code and see if I can identify what exactly the problem is then.
Thank you very much,
Martin
-----Original Message-----
Sent: Monday, October 10, 2005 3:03 PM
To: Chapman, Martin
Cc: gdal-dev at lists.maptools.org
Subject: Re: [Gdal-dev] Possible bug in getGeometryType() version 1.3.0
On Oct 10, 2005, at 2:48 PM, Chapman, Martin wrote:
> Frank,
> When I call pOgrGeometry->getGeometryType(); in version 1.3.0 it
> returns the wrong value (basically an unsigned int value) for esri
> shape files that contain point geometry.  Polygons and LineStrings
> work as expected.  Can you confirm that this is a bug?  This is on
> Windows XP, haven't tried it on Linux yet, but I will shortly.
> Best regards,
> Martin
Martin,
I ran into something like this last night on Linux. The data were
points digitized using QGis 0.7. Ogrinfo reported this shapefile as
containing 3D points, and getGeometryType returned an invalid value. I
used ogr2ogr with -nlt POINT to coerce these into "normal" points with
GeometryType 1.
Sean
Sean Gillies
sgillies at frii dot com
http://zcologia.com
