[Gdal-dev] postgis driver
Bart van den Eijnden BEN at Syncera-ITSolutions.NL
Thu Oct 13 07:41:33 EDT 2005
Hi list,
I was running into a problem with the PostGIS driver when trying to get a Mapinfo TAB into PostGIS.
D:\ms4w\apps\stragisweb\htdocs\sites\mdwh\data\gebiedsgericht\geo>ogr2ogr -f "PostgreSQL" PG:"host=127.0.0.1 user=postgres password=stragisweb dbname=mdwh" basisgebieden_conept4.TAB
ERROR 1: INSERT command for new feature failed.
ERROR:  new row for relation "basisgebieden_conept4" violates check constraint "
enforce_geotype_wkb_geometry"
ERROR 1: Terminating translation prematurely after failed
translation of layer basisgebieden_conept4
After debugging the SQL statements I found out that the geometry type was set to polygon, and the Mapinfo file also contained Multipolygons, so I could solve this by using:
D:\ms4w\apps\stragisweb\htdocs\sites\mdwh\data\gebiedsgericht\geo>ogr2ogr -f "PostgreSQL" PG:"host=127.0.0.1 user=postgres password=stragisweb dbname=mdwh" basisgebieden_conept4.TAB -lco OVERWRITE=YES -nlt MULTIPOLYGON
I have a few questions/remarks about the driver:
1) schema support is really needed, since now everything ends up in public
2) would it be a good idea to let the driver create indexes already on the geometry column, oid and the ogc_fid columns and do a vacuum analyze after that? Or are there reasons not to want this?
Thanks for this driver btw!
Best regards,
Bart
Syncera IT Solutions
Postbus 270
2600 AG  DELFT
tel.nr.: 015-7512436
email: BEN at Syncera-ITSolutions.nl
