[Gdal-dev] MrSID ESDK 5.x
Chapman, Martin MChapman at sanz.com
Thu Oct 13 20:54:58 EDT 2005
Frank,
It compiled fine, but there was one error in nmake.opt file.  On the
last line of the mrsid esdk options:
Incorrect:
MRSID_LIB =	$(MRSID_DIR)\lib\Release_md\lti_esdk_dll.lib
$(MRSID_LIB)-
The - at the end of the line was giving the compiler errors.  I removed
it and then it compiled.  I hope that - wasn't needed.
Correct:
$(MRSID_LIB)
Thanks for your help,
Martin
-----Original Message-----
From: fwarmerdam at gmail.com [mailto:fwarmerdam at gmail.com] On Behalf Of
Frank Warmerdam
Sent: Thursday, October 13, 2005 5:12 PM
To: Chapman, Martin
Cc: gdal-dev at lists.maptools.org
Subject: Re: [Gdal-dev] MrSID ESDK 5.x
On 10/13/05, Chapman, Martin <MChapman at sanz.com> wrote:
> I have the MrSID ESDK 5.x and I want to link it to the Windows build
of
> GDAL.  Has the windows build been updated to support this version yet?
I
> noticed in the nmake.opt file that the define symbol said MRSID_FLAGS
> -DMRSID_ESDK_VERSION_40 $(MRSID_FLAGS).  Can I just substitute that
with
> _50?
Martin,
You now need to define MRSID_ESDK instead of
MRSID_ESDK_VERSION_40.   I'm not sure if there
are differences with the library.
Best regards,
I set the clouds in motion - turn up   | Frank Warmerdam,
warmerdam at pobox.com
