[Gdal-dev] MrSID ESDK 5.x
Chapman, Martin MChapman at sanz.com
Thu Oct 13 21:20:38 EDT 2005
Frank,
Wow, mrsid is way faster now through gdal.  I can open a 1.2 GB sid file
and display it in a couple of seconds.  Great job speeding it up.  Did
you change anything?
Martin
-----Original Message-----
From: fwarmerdam at gmail.com [mailto:fwarmerdam at gmail.com] On Behalf Of
Frank Warmerdam
Sent: Thursday, October 13, 2005 6:57 PM
To: Chapman, Martin
Cc: gdal-dev at lists.maptools.org
Subject: Re: [Gdal-dev] MrSID ESDK 5.x
On 10/13/05, Chapman, Martin <MChapman at sanz.com> wrote:
> Frank,
> It compiled fine, but there was one error in nmake.opt file.  On the
> last line of the mrsid esdk options:
> Incorrect:
> MRSID_LIB =     $(MRSID_DIR)\lib\Release_md\lti_esdk_dll.lib
> $(MRSID_LIB)-
> The - at the end of the line was giving the compiler errors.  I
removed
> it and then it compiled.  I hope that - wasn't needed.
> Correct:
> $(MRSID_LIB)
Martin,
The "-" was a typo, I have removed it as well as updating
the -DMRSID_ESDK thing.
Best regards,
I set the clouds in motion - turn up   | Frank Warmerdam,
warmerdam at pobox.com
