[Gdal-dev] Comparing Barely-Different SpatialRef Objects with .IsSame
Christopher Michaelis cmichaelis at happysquirrel.com
Fri Oct 14 19:04:49 EDT 2005
Hi there,
I'm trying to compare two proj4 strings by loading each one into an
OGRSpatialReference object using .ImportFromProj4(), then comparing them
using .IsSame().
The problem that's arising is that the two are just barely off
(.0000000001 off on the y_0 parameter). Therefore, .IsSame() is
returning false.
So, my question for the crowd is, how can I detect this condition and
actually catch these two as equivalent?
The two strings in question are:
"+proj=lcc +lat_1=38.33333333333334 +lat_2=39.83333333333334
+lat_0=37.66666666666666 +lon_0=-122 +x_0=2000000 +y_0=500000.0000000001
+ellps=GRS80 +datum=NAD83 +to_meter=0.3048006096012192 +no_defs"
+lat_0=37.66666666666666 +lon_0=-122 +x_0=2000000 +y_0=500000.0000000002
Any thoughts? BTW, I'm using GDAL 1.3.0.
Thanks,
Chris Michaelis
