[Gdal-dev] Having problems with gdaladdo
Sat Oct 15 18:17:16 EDT 2005
On 10/13/05, Steven Bowden <steveb at bundaberg.qld.gov.au> wrote:
> Hi List,
> I am relatively new to using gdal to process my orthophotos.  I am using
> mapserver to publish the orthos in a web app.
> I am trying to use gdaladdo to create the overviews for the tif files but I am
> getting some strange results in the tif files after I have created the
> overviews.  The second last overview is corrupted and the last/smallest
> overview always has a yellow square in the bottom right right hand corner of
> the image.
Steven,
I have found this problem and committed a fix.  The bug is pretty
serious and is due to the "final block" flushing logic not ensuring
that the block was being written to the correct overview.  I think
this bug has existed for quite a while, though it would only popup
sometimes when writing pixel-interleaved multiple overviews.
So, the fix is in CVS but you can apply it to your code too if needed.
Just call SetDirectory() in GTiffDataset::FlushBlockBuf()
CPLErr GTiffDataset::FlushBlockBuf()
    int		nBlockBufSize;
    CPLErr      eErr = CE_None;
    if( nLoadedBlock < 0 || !bLoadedBlockDirty )
        return CE_None;
    SetDirectory();   <-- add this line
    if( TIFFIsTiled(hTIFF) )
        nBlockBufSize = TIFFTileSize( hTIFF );
    else
        nBlockBufSize = TIFFStripSize( hTIFF );
Thanks for bringing this to my attention.
Best regards,
