[Gdal-dev] Warping from a full disk image of the Earth
Ed McNierney ed at topozone.com
Fri Oct 21 17:40:29 EDT 2005
Paul -
Could you explain what a ³full disk image² is?  If it¹s a planar image, then
it must be projected somehow, and you¹ll need to know the details of the
current projection before you can then use gdalwarp to convert it to a more
convenient projection.
     - Ed
Ed McNierney
TopoZone.com
On 10/21/05 1:17 AM, "Paul Xander" <paul at qwikcast.com> wrote:
> Hi,
>     I've been trying to determine if 'gdalwarp' is the tool for
> reprojecting a section of a jpeg full disk image of the earth into a
> standard format such as Lambert Equal Area.
> Paul
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20051021/e6bb8a3e/attachment.html
