[Gdal-dev] linux vs windows performance
Ed McNierney ed at topozone.com
Fri Oct 21 22:57:02 EDT 2005
Matt -
I guess you've proven the benefit of translating from network to local
disk!  There is no particular reason (given the limited info you gave)
to think that the OS makes much if any difference.
Was the Windows copy from one local disk to the same physical local
disk?  And was that an IDE disk?
	- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA  01863
Phone: +1 (978) 251-4242
Fax: +1 (978) 251-1396
ed at topozone.com
-----Original Message-----
[mailto:gdal-dev-bounces at lists.maptools.org] On Behalf Of Matt Wilkie
Sent: Friday, October 21, 2005 7:12 PM
To: gdal-dev at lists.maptools.org
Subject: [Gdal-dev] linux vs windows performance
Hello,
In case anyone wonders about the relative performance of gdal on Windows
vs Linux:
Test case: gdal_merge of 154 dems in ArcInfo GRID format totalling 1gb.
Windows, from local disk to local disk:	1hr 15min
Linux, from network to local disk: 15 min
linux machine is 450Mhz & 768mb ram,
Windows is 3Ghz & 2Gb ram,
both dual xeons
cheers,
matt wilkie
Geographic Information,
Information Management and Technology,
Yukon Department of Environment
10 Burns Road * Whitehorse, Yukon * Y1A 4Y9
867-667-8133 Tel * 867-393-7003 Fax
http://environmentyukon.gov.yk.ca/geomatics/
Gdal-dev mailing list
Gdal-dev at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/gdal-dev
