[Gdal-dev] Read/Write Oracle Spatial
Hallgren Johan E jhhal at wmdata.com
Tue Oct 25 10:21:20 EDT 2005
Hello
I have tried to read from OracleSpatial (ver 10.2.0), change some value
and then do an update with the following lines of code (C#).
OGR.Driver d = OGR.ogr.GetDriverByName("OCI");
OGR.DataSource ds = d.Open(@"OCI:wmgis/wmgis01 at WMSI1394", 1);
OGR.Layer l = ds.GetLayerByName("baggis_lines");
OGR.Feature f = l.GetFeature(0);
OGR.Geometry g = f.GetGeometryRef();
g = g.Clone();
double x = g.GetX(0);
double y = g.GetY(0);
double z = g.GetZ(0);
x += 1.0;
y += 1.0;
textBox1.Text += "x="+ x + " y=" + y + System.Environment.NewLine;
l.StartTransaction();
g.SetPoint(0, x, y, z);
f.SetGeometryDirectly(g);
f.SetField("TEXT", "OLLE");
l.SetFeature(f);
l.CommitTransaction();
textBox1.Text += "count=" + l.GetFeatureCount(1) +
System.Environment.NewLine;;
Reading from works fine but when I call the SetFeature method it fails.
The error-message I can see in the Output win is:
ERROR 1: OGROCITableLayer::SetFeature(-1) failed because there is no
apparent FID column on table BAGGIS_LINES.
What's wrong?
What I want was to read a record, change some value and then write it
back.
Any assistance would be great.
Regards
Johan
__________________________________
Johan Hallgren
WM-data
Pelle Bergs backe 3
Box 1938, 791 19 Falun
Tel: 023-844 65 (int: +46-2384465)
Mobil: 070-588 44 28 (int: +46-705884428)
johan.e.hallgren at wmdata.com <mailto:johan.e.hallgren at wmdata.com>
http://www.wmdata.se <http://www.wmdata.se>
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20051025/9297d4c5/attachment.html
