[Gdal-dev] gdal-grass plugin
Tue Oct 25 15:12:00 EDT 2005
On 10/25/05, William Kyngesburye <woklist at kyngchaos.com> wrote:
> I finally got around to trying this.  I had to add '-lgrass_dbmibase -
> lgrass_dbmiclient' to LIBS so it could find the _db_* symbols.
> Otherwise, works great.  Much simpler than the old way (and I've been
> having troubles with the old way recently on an older system).
William,
I have added the dbmi dependency and re-uploaded as;
  http://www.gdal.org/dl/grass-gdal-1.3.1.1.tar.gz
Let me know if this works ok "out of the box" for you.
Best regards,
