[Gdal-dev] gdal-grass plugin rpm
Wed Oct 26 11:28:55 EDT 2005
On 10/26/05, Otto Dassau <dassau at gdf-hannover.de> wrote:
> ok, it happens in gdal itself, but building the gdal rpm package I also
> defined /usr as prefix, so how can I change this and make gdal look
> in /usr/lib/gdalplugins?
Otto,
Are you saying that GDAL was configured with --prefix=/usr but
the cpl_config.h has a GDAL_PREFIX of "/usr/local"?  That
shouldn't happen.  Could you confirm that before I start digging
into the configure magic?
Best regards,
