[Gdal-dev] gdal-grass plugin rpm
Otto Dassau dassau at gdf-hannover.de
Thu Oct 27 03:28:00 EDT 2005
Am Mittwoch, 26. Oktober 2005 19:36 schrieb Frank Warmerdam:
> On 10/26/05, Otto Dassau <dassau at gdf-hannover.de> wrote:
> > yes, I can confirm this - unfortunately. I will send you my spec files
> > offlist.
> Otto,
> I have reviewed your spec file, and it seems to configure with the
> default prefix, and then try to override it at make time.  However,
> the configure is dumping the prefix into gdal/port/cpl_config.h
> at configure time and that can't be overridden at build time.
> This is not something I am keen to change.
Hi Frank,
no problem, I added the missing --with-prefix and all is workin fine now!
thanks a lot
  Otto
