[Gdal-dev] Read/Write Oracle Spatial
Fri Oct 28 10:21:41 EDT 2005
On 10/28/05, Hallgren Johan E <jhhal at wmdata.com> wrote:
> Silly questions...
> You are mention that you have committed a change in
> CVS, you are also asking me to do some tests on that. I would be glad to
> do it but where can a get the source. With CVS do you mean
> http://cvs.maptools.org/query.cgi? Can I get some source code to
> recompile there?
Johan,
The newest code is now in CVS (the source control system for GDAL).
There are nightly snapshots from CVS made available at:
  http://dl.maptools.org/dl/gdal/daily/
You can also use a CVS client to pull the very latest, but last
nights snapshot should be fine for your purposes.
Best regards,
