[Gdal-dev] Re: [FWTools] gdal_merge.bat
Matt Wilkie matt.wilkie at gov.yk.ca
Fri Oct 28 11:59:02 EDT 2005
Travis Kirstine GIS Tech wrote:
> Is it possible to create multiple outputs with the gdal_merge.bat.  I've
> been creating a batch file and running it in the FWTool shell without much
> success e.g.
> my_merge.bat
> gdal_merge.bat -o out_1.tif -of GTiff in_1.tif in_2.tif in_3.tif
> gdal_merge.bat -o out_2.tif -of GTiff in_3.tif in_4.tif in_5.tif
> This process works but only creates the out_1.tif.
Hi Travis, I think you've encountered the same problem I just finally
solved yesterday. On Windows gdal_merge needs to be CALL'd else the
control doesn't return to the original batch file:
@echo off
:: My_Merge.bat
CALL gdal_merge.bat -o out_1.tif -of GTiff in_1.tif in_2.tif in_3.tif
CALL gdal_merge.bat -o out_2.tif -of GTiff in_3.tif in_4.tif in_5.tif
echo --- Done!
cheers,
matt wilkie
Geographic Information,
Information Management and Technology,
Yukon Department of Environment
10 Burns Road * Whitehorse, Yukon * Y1A 4Y9
867-667-8133 Tel * 867-393-7003 Fax
http://environmentyukon.gov.yk.ca/geomatics/
