[Gdal-dev] changes to ArcGIS data store coming
Matt Wilkie matt.wilkie at gov.yk.ca
Fri Oct 28 16:15:36 EDT 2005
Gdal Developers,
In version 9.2 of ArcGIS ESRI will be introducing a new data store to
supplant ms-access personal geodatabases. They are promsing to publish
an open API to the new store the same way they did for shapefiles.
Upcoming changes to geodatabases in arcgis 9.2:
http://www.esri.com/news/arcnews/summer05articles/managing-spatial-data.html
Things which caught my attention (mostly near the bottom):
"Archiving Geodatabase History — A key goal of ArcGIS 9.2 is to allow
efficient storage and query of historical database states
"Double Precision —  [for] The entire GIS stack ... This allows a single
spatial domain to be used for the whole globe (!)
"File-Based Geodatabase — At ArcGIS 9.2, the complete functionality of a
personal geodatabase and its complete information model have been
implemented on top of a file system. File-based geodatabases fully
support vector; raster; terrain; annotation; and all other geodatabase
data types, rules, and relationships without the performance and
geodatabase size limitations of a Microsoft Access database. In
performance tests to date, the file-based geodatabase implementation not
only outperforms the Microsoft Access personal geodatabase, but it also
outperforms the shapefile for display and query operations."
On the FME wiki there is a small note saying the API itself won't be out
for v9.2 "ESRI tell us that they have a C++ api in the pipeline for this
format. That would be great because we wouldn't need to use ArcObjects
and therefore users wouldn't need ArcGIS installed to write to it from
FME. It's not specified when this will be - but it won't be in v9.2"
http://www.fmepedia.com/index.php/Support_-_Geodatabase_FAQ
cheers,
matt wilkie
Geographic Information,
Information Management and Technology,
Yukon Department of Environment
10 Burns Road * Whitehorse, Yukon * Y1A 4Y9
867-667-8133 Tel * 867-393-7003 Fax
http://environmentyukon.gov.yk.ca/geomatics/
