[Gdal-dev] ECW Still hanging - is running on SMP a problem?
James Browne James.Browne at liu.edu
Fri Sep 2 09:59:54 EDT 2005
Bill,
  Thanks! I'll try them and get back to you. I should have a chance to dive into this later today and over the weekend.
                 Jim
-----Original Message-----
Sent: Fri 9/2/2005 2:06 AM
To: James Browne; Tom Lynch
Cc: GDAL Developer List
Subject: RE: [Gdal-dev] ECW Still hanging -  is running on SMP a problem?
James,
I have put together a collection of three fixes into a patch that might
get you through this.  Each one has reduced my hanging issues
considerably, and I am now seeing my conversions progress.  There might be
more, but for now I'm working.
I've included it below.  You can apply it with
patch -p1 < patch.file
in your top-level ecw directory or
patch -p2 < patch.file
from your Source directory.
I hope this helps.
Bill
diff -rc orig/Source/C/NCSEcw/NCSEcw/ncscbm.c ecw32beta/Source/C/NCSEcw/NCSEcw/ncscbm.c
*** orig/Source/C/NCSEcw/NCSEcw/ncscbm.c	2005-06-11 18:27:06.000000000 -0400
--- ecw32beta/Source/C/NCSEcw/NCSEcw/ncscbm.c	2005-09-01 18:27:39.762737634 -0400
*** 1181,1189 ****
  	if(NCScbmGetFileBlockSizeLocal(pNCSFile, nBlock, &length, &offset)) {
  		QmfLevelStruct	*pTopQmf = pNCSFile->pTopQmf;		// we always go relative to the top level
  		UINT32  nPaddedLength = 1;
! 		while(nPaddedLength < length) {
! 			nPaddedLength *= 2;
  		*pBlockLength = length;
--- 1181,1194 ----
! 		if (length %4 == 0) //on a word boundary
! 			nPaddedLength = length;
! 		else
! 			nPaddedLength = (((int)(length/4)) + 1) *4;
diff -rc orig/Source/C/NCSEcw/NCSEcw/NCSEcw.cpp ecw32beta/Source/C/NCSEcw/NCSEcw/NCSEcw.cpp
*** orig/Source/C/NCSEcw/NCSEcw/NCSEcw.cpp	2005-06-11 18:27:06.000000000 -0400
--- ecw32beta/Source/C/NCSEcw/NCSEcw/NCSEcw.cpp	2005-09-02 01:47:48.858287669 -0400
*** 1019,1025 ****
  				NCSEcwStatsDecrement(&pNCSEcwInfo->pStatistics->nUnpackedBlocksCacheSize, pNextCachedBlock->nUnpackedECWBlockLength);
  				NCSEcwStatsUnLock();
! 			pNextCachedBlock = pNextCachedBlock->pNextCachedBlock;
--- 1019,1036 ----
! 			if (pNextCachedBlock == pNextCachedBlock->pNextCachedBlock)
! 			    /*Get rid of simple self-cycles here*/
! 			    pNextCachedBlock = NULL;
! 			else
! 			    /*And prevent bigger problems here*/
! 			    NCSFileCachedBlock *prevBlock = pNextCachedBlock;
! 			    prevBlock->pNextCachedBlock = NULL;
diff -rc orig/Source/C/NCSUtil/thread.c ecw32beta/Source/C/NCSUtil/thread.c
*** orig/Source/C/NCSUtil/thread.c	2005-05-24 09:37:20.000000000 -0400
--- ecw32beta/Source/C/NCSUtil/thread.c	2005-09-02 01:44:59.110019686 -0400
*** 202,207 ****
--- 202,210 ----
  		NCSThreadInfo *pThreadInfo = (NCSThreadInfo*)NCSMalloc(sizeof(NCSThreadInfo), TRUE);
  		NCSMutexBegin(&mMutex);
+ 		pThreadInfo->bThreadRunning = FALSE;
  		pThreadInfo->tid = tidNextTID++;
  		NCSMutexEnd(&mMutex);
*** 271,276 ****
--- 274,282 ----
  	if( pThreadInfo ) {
*** 356,361 ****
--- 362,370 ----
