[Gdal-dev] gdalwarp doesn't honour my GCPs
Vincent Schut vincent at ecovla.nl
Mon Sep 5 02:46:45 EDT 2005
Maciek Sieczka wrote:
> Dear All,
> I have a tif+tfw file. It's georeferencing is *very* loose, so I added 118
> GCPs *[1] and tried to gdalwarp it, using these GCPs, to correct the
> georeferencing. However, gdalwarp outputs a clone of input file instead of
> warping *[2]. You can see that corner coordinates of input and output are
> identical, in spite of GCPs present in the input... What's wrong (with
> me?)?
Maciek,
have you tried it without the tfw file? The presence of a tfw file might
well get in the way of your gcp's, as the tfw file already gives your
image its corner points. I'd say, rename your tfw file to .tfw.bak or
something, and try gdalwarp again.
Good luck,
Vincent.
> If my input file with GCPs is needed for investigation, grab it here:
> http://www.biol.uni.wroc.pl/sieczka/udostepnione/prochowice_z5_gdtr.tif.tar.bz2
> (9,9 MB).
> Thanks for any hints!
> Cheers,
> Maciek
> [1]
> [trawiarz at quercus ~]$ gdal_translate `cat GCPs.txt` prochowice_z5_gimp.tif
> Input file size is 3334, 5568
> 0...10...20...30...40...50...60...70...80...90...100 - done.
> ERROR 6: SetColorTable() not supported for this dataset.
> #     that's another thing, I've filled a bug report on that today
> [trawiarz at quercus ~]$ gdalinfo prochowice_z5_gdtr.tif
> Driver: GTiff/GeoTIFF
> Size is 3334, 5568
> Coordinate System is `'
> Origin = (5592805.032917,5686085.775819)
> Pixel Size = (2.11666667,-2.11666667)
> GCP Projection =
> GCP[  0]: Id=1, Info=
>          (5.594e+06,5.675e+06) -> (5.594e+06,5.675e+06,0)
> GCP[  1]: Id=2, Info=
>          (5.595e+06,5.67498e+06) -> (5.595e+06,5.675e+06,0)
> GCP[  2]: Id=3, Info=
>          (5.596e+06,5.67497e+06) -> (5.596e+06,5.675e+06,0)
> GCP[  3]: Id=4, Info=
>          (5.597e+06,5.67495e+06) -> (5.597e+06,5.675e+06,0)
> GCP[  4]: Id=5, Info=
>          (5.598e+06,5.67494e+06) -> (5.598e+06,5.675e+06,0)
> GCP[  5]: Id=6, Info=
>          (5.59901e+06,5.67492e+06) -> (5.599e+06,5.675e+06,0)
> GCP[  6]: Id=7, Info=
>          (5.59402e+06,5.676e+06) -> (5.594e+06,5.676e+06,0)
> GCP[  7]: Id=8, Info=
>          (5.59502e+06,5.67598e+06) -> (5.595e+06,5.676e+06,0)
> GCP[  8]: Id=9, Info=
>          (5.59602e+06,5.67597e+06) -> (5.596e+06,5.676e+06,0)
> GCP[  9]: Id=10, Info=
>          (5.59702e+06,5.67595e+06) -> (5.597e+06,5.676e+06,0)
> GCP[ 10]: Id=11, Info=
>          (5.59802e+06,5.67593e+06) -> (5.598e+06,5.676e+06,0)
> GCP[ 11]: Id=12, Info=
>          (5.59902e+06,5.67592e+06) -> (5.599e+06,5.676e+06,0)
> GCP[ 12]: Id=13, Info=
>          (5.59403e+06,5.677e+06) -> (5.594e+06,5.677e+06,0)
> GCP[ 13]: Id=14, Info=
>          (5.59503e+06,5.67698e+06) -> (5.595e+06,5.677e+06,0)
> GCP[ 14]: Id=15, Info=
>          (5.59604e+06,5.67696e+06) -> (5.596e+06,5.677e+06,0)
> GCP[ 15]: Id=16, Info=
>          (5.59704e+06,5.67695e+06) -> (5.597e+06,5.677e+06,0)
> GCP[ 16]: Id=17, Info=
>          (5.59804e+06,5.67693e+06) -> (5.598e+06,5.677e+06,0)
> GCP[ 17]: Id=18, Info=
>          (5.59904e+06,5.67692e+06) -> (5.599e+06,5.677e+06,0)
> GCP[ 18]: Id=19, Info=
>          (5.59405e+06,5.67799e+06) -> (5.594e+06,5.678e+06,0)
> GCP[ 19]: Id=20, Info=
>          (5.59505e+06,5.67798e+06) -> (5.595e+06,5.678e+06,0)
> GCP[ 20]: Id=21, Info=
>          (5.59605e+06,5.67796e+06) -> (5.596e+06,5.678e+06,0)
> GCP[ 21]: Id=22, Info=
>          (5.59706e+06,5.67795e+06) -> (5.597e+06,5.678e+06,0)
> GCP[ 22]: Id=23, Info=
>          (5.59805e+06,5.67793e+06) -> (5.598e+06,5.678e+06,0)
> GCP[ 23]: Id=24, Info=
>          (5.59906e+06,5.67791e+06) -> (5.599e+06,5.678e+06,0)
> GCP[ 24]: Id=25, Info=
>          (5.59406e+06,5.67899e+06) -> (5.594e+06,5.679e+06,0)
> GCP[ 25]: Id=26, Info=
>          (5.59507e+06,5.67897e+06) -> (5.595e+06,5.679e+06,0)
> GCP[ 26]: Id=27, Info=
>          (5.59607e+06,5.67896e+06) -> (5.596e+06,5.679e+06,0)
> GCP[ 27]: Id=28, Info=
>          (5.59707e+06,5.67894e+06) -> (5.597e+06,5.679e+06,0)
> GCP[ 28]: Id=29, Info=
>          (5.59807e+06,5.67892e+06) -> (5.598e+06,5.679e+06,0)
> GCP[ 29]: Id=30, Info=
>          (5.59908e+06,5.67891e+06) -> (5.599e+06,5.679e+06,0)
> GCP[ 30]: Id=31, Info=
>          (5.59408e+06,5.67998e+06) -> (5.594e+06,5.68e+06,0)
> GCP[ 31]: Id=32, Info=
>          (5.59508e+06,5.67996e+06) -> (5.595e+06,5.68e+06,0)
> GCP[ 32]: Id=33, Info=
>          (5.59608e+06,5.67994e+06) -> (5.596e+06,5.68e+06,0)
> GCP[ 33]: Id=34, Info=
>          (5.59709e+06,5.67993e+06) -> (5.597e+06,5.68e+06,0)
> GCP[ 34]: Id=35, Info=
>          (5.59809e+06,5.67991e+06) -> (5.598e+06,5.68e+06,0)
> GCP[ 35]: Id=36, Info=
>          (5.59909e+06,5.6799e+06) -> (5.599e+06,5.68e+06,0)
> GCP[ 36]: Id=37, Info=
>          (5.59409e+06,5.68098e+06) -> (5.594e+06,5.681e+06,0)
> GCP[ 37]: Id=38, Info=
>          (5.5951e+06,5.68096e+06) -> (5.595e+06,5.681e+06,0)
> GCP[ 38]: Id=39, Info=
>          (5.5961e+06,5.68094e+06) -> (5.596e+06,5.681e+06,0)
> GCP[ 39]: Id=40, Info=
>          (5.5971e+06,5.68092e+06) -> (5.597e+06,5.681e+06,0)
> GCP[ 40]: Id=41, Info=
>          (5.5981e+06,5.68091e+06) -> (5.598e+06,5.681e+06,0)
> GCP[ 41]: Id=42, Info=
>          (5.59911e+06,5.68089e+06) -> (5.599e+06,5.681e+06,0)
> GCP[ 42]: Id=43, Info=
>          (5.59411e+06,5.68197e+06) -> (5.594e+06,5.682e+06,0)
> GCP[ 43]: Id=44, Info=
>          (5.59511e+06,5.68196e+06) -> (5.595e+06,5.682e+06,0)
> GCP[ 44]: Id=45, Info=
>          (5.59611e+06,5.68194e+06) -> (5.596e+06,5.682e+06,0)
> GCP[ 45]: Id=46, Info=
>          (5.59712e+06,5.68192e+06) -> (5.597e+06,5.682e+06,0)
> GCP[ 46]: Id=47, Info=
>          (5.59812e+06,5.6819e+06) -> (5.598e+06,5.682e+06,0)
> GCP[ 47]: Id=48, Info=
>          (5.59912e+06,5.68189e+06) -> (5.599e+06,5.682e+06,0)
> GCP[ 48]: Id=49, Info=
>          (5.59412e+06,5.68297e+06) -> (5.594e+06,5.683e+06,0)
> GCP[ 49]: Id=50, Info=
>          (5.59513e+06,5.68296e+06) -> (5.595e+06,5.683e+06,0)
> GCP[ 50]: Id=51, Info=
>          (5.59613e+06,5.68294e+06) -> (5.596e+06,5.683e+06,0)
> GCP[ 51]: Id=52, Info=
>          (5.59713e+06,5.68292e+06) -> (5.597e+06,5.683e+06,0)
> GCP[ 52]: Id=53, Info=
>          (5.59813e+06,5.6829e+06) -> (5.598e+06,5.683e+06,0)
> GCP[ 53]: Id=54, Info=
>          (5.59914e+06,5.68289e+06) -> (5.599e+06,5.683e+06,0)
> GCP[ 54]: Id=55, Info=
>          (5.59414e+06,5.68397e+06) -> (5.594e+06,5.684e+06,0)
> GCP[ 55]: Id=56, Info=
>          (5.59514e+06,5.68395e+06) -> (5.595e+06,5.684e+06,0)
> GCP[ 56]: Id=57, Info=
>          (5.59614e+06,5.68394e+06) -> (5.596e+06,5.684e+06,0)
> GCP[ 57]: Id=58, Info=
>          (5.59715e+06,5.68392e+06) -> (5.597e+06,5.684e+06,0)
> GCP[ 58]: Id=59, Info=
>          (5.59815e+06,5.6839e+06) -> (5.598e+06,5.684e+06,0)
> GCP[ 59]: Id=60, Info=
>          (5.59915e+06,5.68389e+06) -> (5.599e+06,5.684e+06,0)
> GCP[ 60]: Id=61, Info=
>          (5.59415e+06,5.68497e+06) -> (5.594e+06,5.685e+06,0)
> GCP[ 61]: Id=62, Info=
>          (5.59516e+06,5.68495e+06) -> (5.595e+06,5.685e+06,0)
> GCP[ 62]: Id=63, Info=
>          (5.59616e+06,5.68493e+06) -> (5.596e+06,5.685e+06,0)
> GCP[ 63]: Id=64, Info=
>          (5.59716e+06,5.68492e+06) -> (5.597e+06,5.685e+06,0)
> GCP[ 64]: Id=65, Info=
>          (5.59816e+06,5.6849e+06) -> (5.598e+06,5.685e+06,0)
> GCP[ 65]: Id=66, Info=
>          (5.59917e+06,5.68489e+06) -> (5.599e+06,5.685e+06,0)
> GCP[ 66]: Id=67, Info=
>          (5.59318e+06,5.67462e+06) -> (5.59318e+06,5.6746e+06,0)
> GCP[ 67]: Id=68, Info=
>          (5.59314e+06,5.6857e+06) -> (5.59298e+06,5.68572e+06,0)
> GCP[ 68]: Id=69, Info=
>          (5.59399e+06,5.67462e+06) -> (5.594e+06,5.67461e+06,0)
> GCP[ 69]: Id=70, Info=
>          (5.595e+06,5.67462e+06) -> (5.595e+06,5.67463e+06,0)
> GCP[ 70]: Id=71, Info=
>          (5.596e+06,5.67463e+06) -> (5.596e+06,5.67465e+06,0)
> GCP[ 71]: Id=72, Info=
>          (5.597e+06,5.67463e+06) -> (5.597e+06,5.67467e+06,0)
> GCP[ 72]: Id=73, Info=
>          (5.598e+06,5.67463e+06) -> (5.598e+06,5.67469e+06,0)
> GCP[ 73]: Id=74, Info=
>          (5.599e+06,5.67464e+06) -> (5.599e+06,5.67471e+06,0)
> GCP[ 74]: Id=75, Info=
>          (5.59966e+06,5.67464e+06) -> (5.59966e+06,5.67472e+06,0)
> GCP[ 75]: Id=76, Info=
>          (5.59965e+06,5.6747e+06) -> (5.59965e+06,5.67479e+06,0)
> GCP[ 76]: Id=77, Info=
>          (5.59318e+06,5.67501e+06) -> (5.59317e+06,5.675e+06,0)
> GCP[ 77]: Id=78, Info=
>          (5.59965e+06,5.67491e+06) -> (5.59964e+06,5.675e+06,0)
> GCP[ 78]: Id=79, Info=
>          (5.59963e+06,5.6757e+06) -> (5.59961e+06,5.67579e+06,0)
> GCP[ 79]: Id=80, Info=
>          (5.59317e+06,5.67601e+06) -> (5.59316e+06,5.676e+06,0)
> GCP[ 80]: Id=81, Info=
>          (5.59963e+06,5.67591e+06) -> (5.5996e+06,5.676e+06,0)
> GCP[ 81]: Id=82, Info=
>          (5.59961e+06,5.6767e+06) -> (5.59957e+06,5.67679e+06,0)
> GCP[ 82]: Id=83, Info=
>          (5.59317e+06,5.67701e+06) -> (5.59314e+06,5.677e+06,0)
> GCP[ 83]: Id=84, Info=
>          (5.5996e+06,5.67691e+06) -> (5.59956e+06,5.677e+06,0)
> GCP[ 84]: Id=85, Info=
>          (5.59959e+06,5.67769e+06) -> (5.59953e+06,5.67779e+06,0)
> GCP[ 85]: Id=86, Info=
>          (5.59317e+06,5.67801e+06) -> (5.59312e+06,5.678e+06,0)
> GCP[ 86]: Id=87, Info=
>          (5.59958e+06,5.6779e+06) -> (5.59952e+06,5.678e+06,0)
> GCP[ 87]: Id=88, Info=
>          (5.59956e+06,5.67869e+06) -> (5.59949e+06,5.67879e+06,0)
> GCP[ 88]: Id=89, Info=
>          (5.59317e+06,5.679e+06) -> (5.5931e+06,5.679e+06,0)
> GCP[ 89]: Id=90, Info=
>          (5.59956e+06,5.6789e+06) -> (5.59948e+06,5.679e+06,0)
> GCP[ 90]: Id=91, Info=
>          (5.59954e+06,5.67968e+06) -> (5.59945e+06,5.67978e+06,0)
> GCP[ 91]: Id=92, Info=
>          (5.59316e+06,5.68e+06) -> (5.59308e+06,5.68e+06,0)
> GCP[ 92]: Id=93, Info=
>          (5.59953e+06,5.67989e+06) -> (5.59944e+06,5.68e+06,0)
> GCP[ 93]: Id=94, Info=
>          (5.59951e+06,5.68067e+06) -> (5.59941e+06,5.68078e+06,0)
> GCP[ 94]: Id=95, Info=
>          (5.59316e+06,5.68099e+06) -> (5.59306e+06,5.681e+06,0)
> GCP[ 95]: Id=96, Info=
>          (5.59951e+06,5.68089e+06) -> (5.5994e+06,5.681e+06,0)
> GCP[ 96]: Id=97, Info=
>          (5.59949e+06,5.68167e+06) -> (5.59937e+06,5.68178e+06,0)
> GCP[ 97]: Id=98, Info=
>          (5.59316e+06,5.68199e+06) -> (5.59305e+06,5.682e+06,0)
> GCP[ 98]: Id=99, Info=
>          (5.59948e+06,5.68189e+06) -> (5.59936e+06,5.682e+06,0)
> GCP[ 99]: Id=100, Info=
>          (5.59946e+06,5.68267e+06) -> (5.59933e+06,5.68278e+06,0)
> GCP[100]: Id=101, Info=
>          (5.59315e+06,5.68299e+06) -> (5.59303e+06,5.683e+06,0)
> GCP[101]: Id=102, Info=
>          (5.59945e+06,5.68288e+06) -> (5.59932e+06,5.683e+06,0)
> GCP[102]: Id=103, Info=
>          (5.59944e+06,5.68367e+06) -> (5.59929e+06,5.68378e+06,0)
> GCP[103]: Id=104, Info=
>          (5.59315e+06,5.68399e+06) -> (5.59301e+06,5.684e+06,0)
> GCP[104]: Id=105, Info=
>          (5.59943e+06,5.68388e+06) -> (5.59928e+06,5.684e+06,0)
> GCP[105]: Id=106, Info=
>          (5.59941e+06,5.68467e+06) -> (5.59924e+06,5.68478e+06,0)
> GCP[106]: Id=107, Info=
>          (5.59315e+06,5.68498e+06) -> (5.59299e+06,5.685e+06,0)
> GCP[107]: Id=108, Info=
>          (5.59315e+06,5.68498e+06) -> (5.593e+06,5.685e+06,0)
> GCP[108]: Id=109, Info=
>          (5.5994e+06,5.68488e+06) -> (5.59924e+06,5.685e+06,0)
> GCP[109]: Id=110, Info=
>          (5.59316e+06,5.6857e+06) -> (5.593e+06,5.68572e+06,0)
> GCP[110]: Id=111, Info=
>          (5.59417e+06,5.68571e+06) -> (5.594e+06,5.68574e+06,0)
> GCP[111]: Id=112, Info=
>          (5.59517e+06,5.68571e+06) -> (5.595e+06,5.68576e+06,0)
> GCP[112]: Id=113, Info=
>          (5.59617e+06,5.68571e+06) -> (5.596e+06,5.68578e+06,0)
> GCP[113]: Id=114, Info=
>          (5.59938e+06,5.68572e+06) -> (5.5992e+06,5.68584e+06,0)
> GCP[114]: Id=115, Info=
>          (5.59938e+06,5.68566e+06) -> (5.5992e+06,5.68578e+06,0)
> GCP[115]: Id=116, Info=
>          (5.59717e+06,5.68571e+06) -> (5.597e+06,5.6858e+06,0)
> GCP[116]: Id=117, Info=
>          (5.59817e+06,5.68571e+06) -> (5.598e+06,5.68582e+06,0)
> GCP[117]: Id=118, Info=
>          (5.59918e+06,5.68572e+06) -> (5.599e+06,5.68583e+06,0)
> Metadata:
>  TIFFTAG_DOCUMENTNAME=/home/trawiarz/prochowice_z5.tif
>  TIFFTAG_XRESOLUTION=300
>  TIFFTAG_YRESOLUTION=300
>  TIFFTAG_RESOLUTIONUNIT=2 (pixels/inch)
> Corner Coordinates:
> Upper Left  ( 5592805.033, 5686085.776)
> Lower Left  ( 5592805.033, 5674300.176)
> Upper Right ( 5599862.000, 5686085.776)
> Lower Right ( 5599862.000, 5674300.176)
> Center      ( 5596333.516, 5680192.976)
> Band 1 Block=3334x2 Type=Byte, ColorInterp=Palette
>  Color Table (RGB with 256 entries)
>  <snip>
> [2]
> [trawiarz at quercus ~]$ gdalwarp prochowice_z5_gdtr.tif
> prochowice_z5_gdtr_gdwr.tif
> Creating output file that is 3334P x 5568L.
> :0...10...20...30...40...50...60...70...80...90...100 - done.
> [trawiarz at quercus ~]$ gdalinfo prochowice_z5_gdtr_gdwr.tif
> Size is 3334, 5568
> Corner Coordinates:
>  <snip>
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
