[Gdal-dev] downsampling shapefiles ?
Daniel Morissette dmorissette at dmsolutions.ca
Sun Sep 11 23:01:13 EDT 2005
Frank Warmerdam wrote:
> Nevertheless, I think it would be better to build some broadly useful
> functions (like generlization) directly into OGR.
FWIW, I quickly hacked a LineString downsampling function into a local
copy of ogr2ogr a few days ago. I have attached a patch file that can be
applied to a recent copy of ogr2ogr.cpp if anyone wants to try it. Add
"-gen_tol <value>" to the OGR2OGR command to enable downsampling to the
specified tolerance (specified in the same units as the coordinates of
your data).
This code is still untested and is not ready to officially integrate in
OGR because it supports only LineStrings (other geometry types are left
untouched) and the function should probably be moved to the
OGRGeometryFactory class. Use at your own risk.
Daniel
  DM Solutions Group              http://www.dmsolutions.ca/
Type: text/x-patch
Desc: not available
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20050911/ec929a64/ogr2ogr_generalize.bin
