[Gdal-dev] Imagine overviews option
Fri Sep 16 13:16:39 EDT 2005
On 9/16/05, Chapman, Martin <MChapman at sanz.com> wrote:
> Frank,
> I don't care about specific datasets using different overview formats.
> So, if I understand correctly, I can use the CPLSetConfigOption()
> function to swap between pyramid formats?  If that works, then that
> would suit my needs.  Is that correct?
Martin,
Yes, that is correct.
> Is there any documentation on
> how to use the rrd format on the gdal website?
The HFA_USE_RRD config option is now subtly mentioned near the
bottom of:
 http://www.gdal.org/frmt_hfa.html
