[Gdal-dev] mingw build
Eric Sokolowsky eric.sokolowsky at gsfc.nasa.gov
Fri Sep 16 13:40:47 EDT 2005
On Fri, 16 Sep 2005, Pete Nagy wrote:
> I'm trying to build gdal using mingw and cygwin on windows, but I get a
> configure error:
> checking where python Makefiles are... found
> checking Python makefile... C:\Python24/lib/python2.4/config/Makefile
> missing, python disabled.
> I try to use prebuilt windows binaries whenever possible, and did not
> build python myself.  Does anyone have any hints on getting gdal to
> build with the least amount of effort?  If I just download the python
> source and find this Makefile that gdal seems to be looking for, would
> this be sufficient?
If you don't require python, just use --without-python as an option
to configure. I do this for my builds on Linux, because we don't need
to use gdal from python.
