[Gdal-dev] OGR ODBC problem
Fri Sep 16 17:03:53 EDT 2005
On 9/16/05, jochen at ingenieurteam2.com <jochen at ingenieurteam2.com> wrote:
> Hello list,
> this is my first mail to this list. So please ignore it if it has more noise
> than signal.
> I use OGR with mapserver to query a MS sql server. This works well and
> helped me
> a lot. THANKS. A while ago I profiled the connection and it gave some table
> column
> fetching noise but I ignored this. Because the performance was ok. Today I
> saw this again and I remembered the query of geometry_columns. Looking in
> the code (I love open source) adding this table from postgis to mssql and -
> same problem. Perhaps the column geometry_type should be called type.
> I googled the archived list searched the buglist and found only same column
> swop
> in another source file. If this is an interesting patch for you, used it on
> the
> other side excuse me.
Jochen,
I am hesittant to apply it because I am not sure which layout is "right"
according to the OGC spec, and because it will break things for folks
who have working setups.  But I have at least added a note in the
drv_odbc.html file describing the columns needed in the
geometry_columns table.
Best regards,
