[Gdal-dev] OGRGeometry::Distance
Matthew Perry perrygeo at gmail.com
Mon Sep 19 05:01:01 EDT 2005
Ari,
On 9/18/05, Ari Jolma <ari.jolma at tkk.fi> wrote:
> It might be confusing to document the "intermediate" C/C++ API, which is
> between GDAL C++ and the swig-based language bindings, if that's what
> you mean. I mean from the users' point of view.
I agree. I think the C++ and the C methods are already documented
seperately. What we really need is docs for the swig interface.
However, all the
> swig-based language interfaces should be as similar as possible (or at
> least implement the common base), but I'm not sure if their docs can be
> based on some common meta information. Matthew, I wrote initial docs for
> the swig/Perl bindings, they at least list all existing methods,
Wow. I didn't even know there were ogr/perl bindings! That's OK for me since
looking at Perl code makes my head hurt ;-) Are they available anywhere? How
did you generate these docs?
I was thinking of an automated method to regenerate the docs every time the
bindings changed. Python offers a very simple way to do this with the epydoc
module. You document the classes directly in the code itself using their
basic epytext markup:
def Distance( self, other ):
Returns the minimum distance between this geometry and another.
@type other: OGR.Geometry
@param other: Geometry to calculate distance to.
@rtype: float
@return: Distance between Geometries
return _gdal.OGR_G_Distance( self._o, other._o )
Then run one command to generate the docs:
epydoc -o /www/ogr_docs/ ogr
And you have complete class documentation. I've posted the example at
http://perrygeo.net/ogr_docs/index.html . Of course the
OGR.Geometry.Distance method was the only one I documented so it looks a
little sparse but you get the idea.
This technique would be acceptable IF all the swig interfaces were kept in
sync with the Python version.
Are there similar/better methods out there for maintaing perl docs? It seems
that a solution where we maintain the class documentation in the code itself
would be preferable to maintaining a separate document but this may be my
inexperience talking.
Any thoughts?
Matt Perry
http://www.perrygeo.net
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20050919/bfcc7ea8/attachment.html
