[Gdal-dev] PostGis layers
Thu Sep 22 15:29:34 EDT 2005
On 9/22/05, Charles F. I. Savage <cfis at interserv.com> wrote:
> Hi everyone - working with OGR and PostGis.
> When OGR opens a Postgis enabled database, it finds its layers via this
> query (I added the select g.f_table_name part to show a problem below):
> SELECT c.relname, g.f_table_name FROM pg_class c, geometry_columns g
> WHERE (c.relkind in ('r','v') AND c.relname !~ '^pg'
> AND c.relname ~ g.f_table_name)
> I've pasted the results of this query below.  Note that the
> polygoncorrections and polgyoneconomics layer show up twice!  This is
> caused by this part of the query:
> Shouldn't it be a direct match without a regular expression, like this:
> AND c.relname = g.f_table_name)
Charlie,
I believe you are corrected.  I have committed this change.
Best regards,
