[Gdal-dev] mingw build, MSVCR71.DLL problem
Pete Nagy Peter.Nagy at vexcel.com
Thu Sep 22 15:46:00 EDT 2005
Hi Frank ->
  It may be that python 2.4.x had something to do with it; I've seen
postings of similar problems with other packages.  Thanks.
-> Pete
Pete Nagy                                        tel: (303) 583-0248
Vexcel Corporation                               fax: (303) 583-0246
http://www.vexcel.com                           home: (303) 823-2336
On Thu, 22 Sep 2005, Frank Warmerdam wrote:
> On 9/22/05, Pete Nagy <Peter.Nagy at vexcel.com> wrote:
> >   My question is, can anyone explain the use of msvcr71.dll with gdal?
> > This is a newer dependency; I just needed to grab it when I went to 1.2.6.
> > Why is it needed instead of msvcrt.dll?  Any ideas why the gdal.dll does
> > not have this dependency, and the python module does?  Any ideas of
> > workarounds?
> Peter,
> My understanding is that MSVCR71.DLL is what is used by
> Visual Studio.NET built applications and that Python 2.4 binaries
> are now normally built this way.  Is it possible that switching to Python
> 2.4 actually introduced this requirement?
> I don't know a good solution, though switching back to Python 2.3
> would likely help.
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | Geospatial Programmer for Rent
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
