[Gdal-dev] PostGis layers
Fri Sep 23 10:08:25 EDT 2005
On 9/23/05, Oleg Semykin <oss-dev at rambler.ru> wrote:
> Hi, Frank
> But what about older PostreSQL 7.X version support:
> "Unable to identify an operator '=' for types 'name' and 'varchar'
> You will have to retype this query using an explicit cast"
> See: http://lists.maptools.org/pipermail/gdal-dev/2005-August/006098.html
Oleg,
Doh!   Is there a way of explicitly casting that will work fine on old
and newer without having to use the ~ operator?  How about:
 select c.relname from pg_class c, geometry_columns g where (c.relkind
in ('r','v') AND c.relname !~ '^pg' AND c.relname::text =
g.f_table_name::text);
That seems to work on my 7.1 database and my 8.x database.  I'll
commit that.
Best regards,
